A
Anonymous
Guest
I think you need to go on one of these wonderful courses of self-discovery yourself. Either that or you haven't met many of your cousins.
Damp can come in many forms:
External leaks, internal leaks, penetration above ground lateral penetration below ground, rising damp through hydrostatic pressure, rising damp through capillary action, internal condensation (many possible causes of this), interstitial condensation, hygroscopic salts attracting any form of moisture.
The above may not be exhaustive, but covers most forms.
Without moisture materials turn to dust (we ourselves are 80% water) and it is therefore desirable for all material to have a certain level of moisture. The problem is when moisture becomes excessive and starts causing problems.
Before tackling any damp problem one has to identify what cause or causes of damp have occurred.
The suggestion that there are only two forms of damp is a very inaccurate and unhelpful over-simplification.
The other thing to remember is that the technical methods of dealing with damp can vary. It is a bit like the difference between a plastic Mac and a woollen overcoat. One is designed to keep moisture out, the other 'manages' moisture. Buildings fall broadly into the same two general categories - those that are designed to exclude moisture and those that manage moisture.
Before tackling damp understand what it is you are dealing with and understand the technologies involved.
As for you DAMP, I suggest you go and ventilate somewhere else.
