tobydog
- South Suffolk
Unfortunately we have an issue brewing and it's been going on since we moved in.
Our small utility/cloakroom is a single skin brick (lined) lean to with a tile roof. It's 11ft x 7ft. The floor is tiled but I had a dispute with the surveyor after we moved in 11 years ago that he didn't pick up a damp issue in the floor during the survey. Despite numerous arguments, in the end he repaid his fee of £700 and we both moved on. At the time the floor was flat but overtime the central part has started to bulge, particularly at the toilet end. Also, I have to keep filing down the bottom of the entrance door from the house each winter as it keep catching. I put this down to swelling of the wooden door but I wouldn't expect to have to take something off every year.
I removed a fair amount of the cement floor where it butts up to the house soleplate plinth to give it some breathing space but noticed that the whole floor sits directly onto the soil below. Oddly, at one point there's a large void.
My question is, can I fix this problem without digging up and replacing the whole floor? It's not bad enough to justify that and it would need to be a limecrete floor as I wouldn't want a plastic membrane up against the main house plinth. Can I do a localised fix just were it's bulging? Self leveling screed isn't really an option due to the toilet and fixed built in cupboards. We could live with it but it's obvious in the toilet area and I feel I'm only putting off the inevitable for when we finally move.
Thanks
Thanks
