malcolm
& Clementine the cat
- Bedfordshire
I have noticed a length of lead in the garden with some broken tiles glued to it. So now I have a chance to sort this awkward bit out properly and am looking for ideas.
It's a parapet wall. On one side is a pitched roof and on the other a vertical drop. I'm not a roofer but I'm inclined to cut a bit of leading into the wall above the slates to close the gap at the top of the slates however I finish it off. Some red tiles would be nice to finish the top of the vertical bit of the wall. How do you attach those? Just cement or a few holes drilled into the bricks for pegs?
It would be nice to have some sort of capping, but the angle is wrong. I have a big dangerous 9 inch thing and could change the angle I suppose so I can put some ridge tiles on top and maybe forget about any additional tiles. It's lime so I could also modify the bricks at ground level. If I only used ridge tiles should there be anything underneath in case the pointing on the ridge tiles failed?
Any ideas or tips? Does this sound close to the mark? Also and importantly do you just use cement for gluing ridge tiles on or are there more storm resistant methods. Photos below and a link to a page where the photos can be made bigger.
The front of the parapet wall is finished with bricks cut at an angle all the way along. The photo shows the first one in place.
This is the effort made by the roofers before it blew off. It was a rubbish solution.
And the structure underneath shown here: http://www.the-salutation.co.uk/blog/rebuilding-the-parapet-wall/
