Bayliss
- Bury St Edmunds Suffolk
With my son we are going to lime plaster the external walls of his double garage, so a fair amount of mixing required. My question is would a electric drum mixer be suitable, apparently they drum rotate 28/30 rpm. The alternative is the plaster whisk on a power drill, which for the amount we need to mix is very much hard work. (I’m a pensioner ) We are going to use the pre mix lime in a bag material.
