- Shropshire, England
My experience is that as long as it's as easy for them as possible and not obviously unsafe, they'll be helpful and do as asked. If you've got a pre-prepared route with holes drilled, furniture moved, floorboards up or whatever I've always found the engineers to be helpful.
They've got a set amount of time allocated to each job so as long as it won't hold them up for the next job, i.e. take longer than a "standard" install, they're generally OK.
