& Clementine the cat
- Bedfordshire
I've not actually painted yet but I have got some bits at the bottom of some walls where water will continue to want to come through and evaporate unless I do something very time consuming. I am concerned that stains will come through.
The walls are ground floor and are coated with concrete render and gypsum. The internal ground levels on the other side of the walls are 8 inches higher than room floor level. I've removed impervious coatings from the wall and the plaster has dried out over a few months.
What is anyone's experience for this sort of thing? I'm planning to leave things as they are as much as possible and let the water come through and evaporate. I'm worried I'll get stains.
