Hi, this is a call for help. What steps should I take to make this room dry and useable?
My family and I have recently moved into a house. The oldest section of the house seems to have damp issues a room we would like to use but currently don’t.
I initially noticed a damp smell in this room and that the plaster had blown away up to a foot from the floor. Also the electrics were tripping whenever something was plugged in. Since disconnected. In addition the previous occupants used the room to grow plants.
I will list the symptoms here
Always damp stone in chimney
Smelly room (has improved)
Blown plaster and render (cement plaster)
Rotten carpet fastener and carpet underlay close to walls
Poured concrete floor coming away near wall, exposing damp proof membrane (Does not reach wall) and liquid membrane painted upto first stone.
I have tinkered with the room, pulled up carpet and knocked off old plaster and render. I have also put in a constant source of heat in the room. The smell has really improved. It looks as if the exposed stones have lime mortar but have been capped with cement and pea sand mortar.
The internal damp stone seems to line up with a wet stone outside
We have also had a french drain dug outside the house this exposed an air brick which was underground, it suggests that at some point the room had a suspended floor. It is now a concrete floor. But could be dug up.
Interestingly under the radiator there is a hole in the wall which seems to have a breeze. Not a clue what this is as it doesn’t match with a hole outside.
Also the concrete floor and dpm does not go up to the wall about an inch short. It looks like the gap was painted with liquid dpm or some such and then filled with mortar.
The house is solid standstone on footings.
The room has three external walls and is ca. 12 ft square.
Has a double radiator with 10mm pipes. Very poor flow and slow to heat. We look to replace with 15mm pipes in the summer.
Electric osmosis system throughout ground floor of house drilled into wall. Have been told this is useless. System came with the house.
The outside of the wall is lime mortar capped with cement.
So really this is a cry for some advice. I don’t intend to do the work myself but any help on a strategy to remedy would be most appreciated.
