overlander matt
As part of the work to convert a room into a bathroom, I plan to install a cast iron soil stack to replace a plastic one and to connect a plastic 100mm pipe to the stack keeping as much plastic out of sight as possible. To do this I was thinking about fitting a T-piece to the vertical stack then a short straight pipe connecting to a 90 deg elbow which should line up with the hole made using a core drill. The question is how to connect the plastic pipe into the cast iron fitting? Has anyone else done anything similar and could share their experience?
Thanks,
Matt
Thanks,
Matt
