Yes previously didn’t have any compliance cert which meant we’d never be able to sell anyway. That will all be in place by the time they’re done, not sure what their final plan is but as far as I know they following the instructions from the SE. We were waiting some time before they were sent theough so they wouldn’t touch it til those instructions were provided.@Notlbishop are you going through Building Control for regularisation?
Has he used a flitch beam.
To my mind, those bits of wood are likely to compress in the future (they are not even a hardwood like oak etc) resulting in a slight beam movement and anything supported by it. It may be structurally sound in the sense that nothing will collapse but surely it will mean some movement in the future. I'm not saying it's wrong as I'm not an SE, and the fact that there IS an SE apparently involved in checking this work probably means it is ok. I'm just surprised, that's all.
Quite common for houses to be sold without BC. Solicitors just take out indemnity insurance. Mortgage companies are usually happy with this as I understand it.You can still sell on, but it would need a sign-off after current updating work. If the BC doesn't sign you off, you sell via an auction house or your estate agent stipulates cash buyer only, as a mortgage won't be possible. Don't tell your own mortgage company - just saying!
Ah yes, true.Quite common for houses to be sold without BC. Solicitors just take out indemnity insurance. Mortgage companies are usually happy with this as I understand it.
No i’m 99% sure we’re not in a conservation area. A quick postcode search confirms the same.Thank you for the photos, they do help with the context. It also occurred to me, are you in a conservation area?
Another thing that occured to me, planning, conservation and building regs only came about and were new in the 80s, you may find that work on your house was done before this. Apparently it was quite normal, although how the rooms above didn't collapse, I don't know.
As well as the SE input, perhaps find the name of the (building!) Conservation Officer for Dorset Council - PlanningConservation@dorsetcouncil.gov.uk - as well as the afforementioned Listed Property Owners Club ( https://www.lpoc.co.uk/ ). These people will be your friend throughout this exercise. They will also be able to advise you on what should be done in their eyes, which can often be different from Building Control regs, as they have a more sympathetic approach to these older buildings, whereas building control only really deal in textbook house building regulations (that annoyingly change every few years anyway).
Looking at these photos, on closer inspection and with the added knowledge that you have this render, it doesn't surprise me in the slightest you have these cracks in the plaster. The moisture has been sucked out of the wall from both sides (cement render and plaster), so this has caused the crumbly mortar bed.
It does look like you are missing a support beam over your window. Again, acrow props supporting a solid plank of wood in the meantime but; for that era, an oak, concrete or reinforced steel beam positioned and encapsulated correctly, if there are cracks above the window.
Please do not allow the builder to employ a plasterer, as they will undoubtedly use gypsum plaster 'for quickness and cheapness'.
Better you think of the 'house health' first and employ one of the few lime plasterers out there... or... clean up the exposed brick and use a feature colour of Earthborn Claypaint (sadly one of the only paints that haven't been bought out and cheapened with acrylic additives).
There are a number of suppliers of lime putty as it's known, but not many plasterers based your way (not on LPOC books anyway, you may have more luck contacting the below companies and see if they can recommend one.
www.limerepair.com (based in Somerset)
https://www.limestuff.co.uk/ (supplier based in Wiltshire)
www.mikewye.co.uk (supplier of various, but also has an in-house 'Building Biologist'(!)
www.roseofjericho.co.uk (supplier and advisor based in Dorchester, Dorset)
www.heritagecobandlime.com (supplier in Devon)
lol that builder sounds a bit of drama queen. The mortar in my 200+ year old house can be a bit crumbly in places, built on clay that sways and heaves like Carol Vorderman's t*** in a wind tunnel, zero foundations - no cracks here.View attachment 18285View attachment 18286View attachment 18287View attachment 18288Hi all, just joined. Was hoping to explain the situation we’re in and whilst i realise its difficult for anyone to be definitive hoping to get your opinions and experiences.
So some context. We live in a 1930s build, semi detached, 3 bedroom.
The building had some remodelling done in the kitchen some time ago before we bought it, a kitchen and diner was made into one room. No regulations were followed and as first time buyers we didn’t ask.
We’ve noticed cracking appear in the kitchen and upstairs in the spare room directly above. This is on the party wall. We know the neighbours had it, not that i’ve seen it but understand it was quite bad. They went through insurers in 2022 and they sent out an independent company, they went through the floorboards, found no signs of subsidence but suggested lateral movement caused by our previous remodelling and fix by stitching using helibars and resin. They sent us the report, i don’t believe they’ve made any fixes recommended.
We noticed the cracks appearing in our kitchen, spareroom and spare room ceiling getting worse, all on the party wall. We brought in builders and SE who uncovered the plaster and found three issues
He did not use steel (sp?) beam to support removal of the wall
He did not use suitable lintel for outside windows
Cracks in the brickwork leading up to spare room.
The first two issues appear to have a ‘simple’ solution and are in hand.
The third one, the cracks is what is concerning. The SE also said there are no other signs of subsidence, the chimney has been inspected, a drain survey also done and came back all good.
The fix has been suggested as also helibars and resin. This is currently underway.
The builder said something today that has knocked us for 6 to be honest. Whilst speaking to him about how they’re getting on he said he has returned to the SE because he believes our mortar is crumbling. He picked up a small section and crushed it in his hand and was very sandy. I asked what this meant and he said it was likely we would see this cracking issue appear elsewhere in the house and the only way to resolve is to demolish the house and rebuild! I know this isn’t covered under our insurance, and we would lose everything. I’ve included photos of the various stages of what’s happened so far.
Have any of you ever come across anything like this before? I think it’s the extremity of saying demolition is the only solution is what has sent us. Obviously very worried. Apologies if the explanation is overlong, i just wanted to provide as much detail as possible. Thanks for reading if you made it this far!
I can't follow all the technical info, but you get a like for Carol Vorderman's T$$$.lol that builder sounds a bit of drama queen. The mortar in my 200+ year old house can be a bit crumbly in places, built on clay that sways and heaves like Carol Vorderman's t*** in a wind tunnel, zero foundations - no cracks here.
I’m just so confused on how we got here, what has caused the issues and what needs fixing and what to do next.
My eye was drawn to the beam supports - is it really ok to use use some timber pads as shown or are they just temporary while the beam is being located in position and will be replaced by a padstone of some sort as the final solution?
Coo... what did I miss?The bearing timbers aren't an issue. The house is being demolished and rebuilt next year.
Loads of great info. I've learnt today that render and plaster suck all the moisture out of the brick joints and wreck it.Coo... what did I miss?
I got that one and am still puzzling over how that works but saw nothing about the place being demolished - except the thoughts/idea of a contractor?Loads of great info. I've learnt today that render and plaster suck all the moisture out of the brick joints and wreck it.
Yup, render is the external 'plastering' of a wall. Styles are all different, but it's especially common in areas exposed to adverse weather conditions.No i’m 99% sure we’re not in a conservation area. A quick postcode search confirms the same.
Just to confirm terminology - by render do you mean the concrete cladding on the outside coupled with the plaster used on the inside has caused the drying out?
On the plasterer they have one coming in, but feel we’re along way from that happening anyway
But before the plasterer how do i fix what we’ve found in your opinion. Is the stitching of the cracks not a good idea?
Issue - cracks in the outside cladding. Caused by - no lintel. Fix - lintel above windows / doors. Not started yet.
Issue - wrong beam used in the kitchen. Caused by - previous dodgy work. Fix - new flitch beam. Started. Need to check - correct pad stones used (?)
Issue - crumbly mortar. Caused by - cement cladding and plaster drawn moisture out of mortar (?) - fix - ?
Issue - cracks in bricks. Caused by - movement of house (?) not sure what’s caused the movement (?) Could crumbly mortar cause cracks in the bricks? Fix - stitching suggested and prepared downstairs. More severe cracks found upstairs referred to SE for now visit tomoro AM. The bricks and mortar (seen in previous pic) holding it together is rock solid apart from the top
I think that’s the best of my knowledge right now.
