I'm buying a G2 listed property.
It's been neglected for some years and one wall is saturated where the gutter has been pouring down the external brick.
The guttering was temporary repaired back in January, but the wall is still very wet to the touch and will likely take a few years to dry out.
When I move in I'll test the plaster to confirm it is lime. I'll try the old vinegar test but I think it is lime.
But I also want to make it look less like an ecosystem is growing on it whilst it's drying out.
I was hoping to remove the modern wallpaper, with some light abrasives to remove the various species of mould along with some sugar soap.
And then lime wash it, and just monitor it for a few years.
Is this the right approach? Is lime washing it a waste of time?
It's listed so I want to avoid taking it back to brick as I will need consent for this. If the plaster is toast, I will obviously have no choice, but if it can be saved I want to try that first.
Anybody experienced with lime that can share any tips?
I'm going to gently warm the room this winter, with windows slightly open for decent ventilation. Will avoid dehumidifiers as this can cause the outer layer of lime to dry too quickly, then it blows off. Or so I've been told.
