I don't know if it would. If it ain't broke comes to mindNo I've never seen that before, looks interesting.
As I said I've no signs of damp that I can see or touch so far. Also my house is a 3 storey over basement, would removing a small section of cement render make that much of a difference to the overall fabric?
So I removed a tiny piece of the plaster in one bedroom & placed it in a cup of vinegar, there was a few bubbles & it's definitely making a fizzing sound when I brought it up to my ear.Yes, if you went the IWI route you'd need to take off the gypsum plaster (for us it was easy peasy as the gypsum plaster was a skim on top of the original lime) and then go from there.The Wood Fibre for us (we've gone for 80mm) has made a tremendous difference. We've had the ability to do it one room at a time which helps. If you can do it properly internally at least that gives one route for the wall to stay dry.
There's no way I'd spend that kind of money doing render. Fundamentally it's not a complex job and I fail to believe there aren't cheaper ways of getting it done. But if there aren't, it's hard to see how you justiy the cost given you're saying you don't have evidence of it causing problems.
Perhaps consider doing one or two rooms internally with wood fibre insulation first, learn from it, and see where that takes you.
If the render has been on there for any length of time, then it's very likely that lime will have been added to the cement mix simply as a plasticiser. If it has always been rendered then the stonework wasn't ever intended to be exposed to the elements and it's weather resistance and appearance are likely to reflect that. If it's been painted then all bets are off as to what was used and what difference that makes.From what you say you may have a cement lime external render, and that will be less prone to cracking and more breathable than a straight cement render.
Not convinced. I was under the impression that the idea that cement renders and gypsum plasters can damage lime mortars was somewhat disputed in that thread. The 'lesson learned' from a very experienced tradesman wasn't all it seemed at face value!Having in recent days seen a suggestion - in a reply to another thread here - that an external cement based render and an internal gypsum plaster could somehow induce the disintegration of the (likely) lime mortar bonding between the bricks/stones of the walls
I thought the assertion was quite firmly made in the comment about render and plaster 'sucking the moisture out of the masonry and mortar'. I'm certainly not convinced but if theres any evidence to support the claim I would love to hear it.Not convinced. I was under the impression that the idea that cement renders and gypsum plasters can damage lime mortars was somewhat disputed in that thread. The 'lesson learned' from a very experienced tradesman wasn't all it seemed at face value!
I might have misunderstood, but the sticking point appeared to be sucking the moisture out while somehow keeping it damp!'sucking the moisture out of the masonry and mortar'
I understood bone dry and then differential movement effectively grinding the mortar to dust.I might have misunderstood, but the sticking point appeared to be sucking the moisture out while somehow keeping it damp!
Prudish? or Poorish? I can see how either might apply, if the house was left naked of its render or the effect that old houses have on the wallet, but neither quite seems to fit the circumstancesI think the Scots have a relevant word that starts with p and ends with ish
I think you have to slur the consonants and bite down on the vowel to get the real feel for the highland terminology.Prudish? or Poorish? I can see how either might apply, if the house was left naked of its render or the effect that old houses have on the wallet, but neither quite seems to fit the circumstances
