stock709
- Queensbury
Hi all,
I’m currently plastering my kitchen and could use some advice from anyone experienced with lime work and old stone walls.
My plan was to fix timber studs in front external walls, then screw on wood wool boards and finish with lime plaster. However, my local lime supplier says I should just plaster directly onto the stone instead — but the walls are pretty uneven and all over the place.
Has anyone done either approach and can share some real-world pros and cons?
Here’s what I’m thinking:
The walls are solid stone (old farmhouse type) and not perfectly dry but not soaking either.
Any practical advice or examples from those who’ve done this before would be really appreciated — especially around how to avoid damp or condensation problems if I go with the stud and board option.
Thanks in advance!
- The stud-and-board route would give me straighter walls and space for insulation or services, but I’m worried about trapping moisture behind the frame.
- Direct lime plaster on the stone keeps it breathable, but the surface is rough and would need a lot of dubbing out.
Thanks in advance!
