So far with our property, everytime we have removed a built in wardrobe, we have uncovered something bad behind it, be it a leak from the roof (which was the final straw which ultimately prompted our new roof), or some interesting modifications to joists/wiring etc.
This is definitely the best one yet, ripping out a built in wardrobe in an upstairs bedroom, I uncovered a chimney breast...
This matches the remains of one long capped off on the roof - initial inspection in the loft had been hampered by the cold water tanks, but from what I could see it appeared that the capped off chimney had been supported with some large timbers in the roofspace to allow the removal of the breast itself beneath. While this wasn't ideal, there isn't much stone above it so I wasn't too worried. It now appears that this wasn't the case...
Feeling somewhat nervous I nipped downstairs to the dining room beneath to find a completely flat plasterboard & studwork wall. Some initial exploratory holes at the base of the studwork revealed some debris from jackdaw nests... so the lower chimney breast had been removed...
I then carefully drilled and cut away a small amount of plasterboard from the ceiling of the dining room - now stood effectively underneath the first floor chimney breast. From what I can see through the small hole there appears to be just some yellow painted 4 x 1 timber above the plasterboard :shock: i.e. supporting the weight of the remaining upstairs breast! I haven't yet been able to determine what is holding up this timber but based on previous I'm not holding out a lot of hope that it has been done correctly, and it wouldn't surprise me if this is just bridging the existing joists.
Even if a gantry bracket has been installed I don't hold out much hope for its strength given the age of the lime mortar in the stone walls.
So It looks like a change to the planned schedule, the other half's utility room will have to wait!
As I see it I have three options:
1) Re-instate the lower breast in block work, with appropriate ventilation at the bottom, then when we re-plaster the dining room, hopefully the modern materials won't be too noticeable.
2) Remove the upstairs breast as well and properly support the remaining stack (only protrudes a foot above the roofline so wouldn't be too bad).
3) Steels...
I'm currently leaning towards option 1 - any comments or better suggestions?
Happy bloody Christmas to me... :evil:
3) Steels...
