pieman
- LINCOLNSHIRE
Hi all,
I am after some advice if I may?
We live in an 1877 detached house. We are currently refurbing reinstating many of the Victorian features discarded during the glorious 70's.
We have had every room replastered. I have now noticed on one of our upstairs chimney breasts in a bedroom that there are damp patches appearing on one side of the breast. We last year opened up the fireplace and replaced with a cast iron fire surround etc, I doudt the damp is coming from the roof as the lead flashing around the chimneys was renewed about 2 months ago and the tiles are sound.
The chimney is lined as there is a log burning stove in the dining room below. There used to be a solid fuel boiler that used to be situated where this is, but taken out about 6 years ago.
I recently had a building inspector around and mentioned this to him. He thinks it could be the soot from the chimney has made its way through possible cracks in the chimney lining and is now causing this damp by attracting moisture.
Is this a possibility??
With regards to getting this remidied what are my options. During dry weather the walls appear to dry, would rain coming down the chimney pots cause problems. should I put a cowling on them. Or is there some kind of treatment that can be done internally to fix the problem?
It is only affecting the upstairs breasts to varying degrees, and only on one side, the side that then in the loft is angles toward the centre of the roof, if that makes sense!
Any advice greatly received, many thanks.
Simon.
Simon.
