AMole
- Buckinghamshire
Hi everyone,
I'm hoping someone here can help with a couple of (possibly related) damp issues in our Victorian town house - I've consulted a few so-called professionals and they have just offered up solutions that I'm convinced won't help.
Firstly, a description of the house: it's a 3-storey townhouse, built around 1870. We're at the end of a terrace of four houses and have a gable end wall that faces roughly west. The lowest of the the three storeys is a semi-basement - floor level is around 1.2m below street level. Unusually for a house of this age, it has cavity walls but the gable end in the attic is just a single skin. There are two chimney breasts running up the end wall, each with three flues (hope I've got the terminology right!). The two chimney breasts come together at attic level, with a single stack at the apex of the roof. Of the six flues, only two remain open, the others have been sealed.
The previous owners carried out various "improvements". These included having cavity wall insulation installed (in 2009). As well as the cavity, they seem to have also filled at least one of the chimney flues. (The insulation looks a bit like cotton wool). At the bottom level they knocked two rooms into one and fitted a new kitchen (again around 2009/10). As part of this work, they had a local damp "specialist" apply a waterproof plaster to the walls, which they then painted with some kind of vinyl paint. They also had vinyl flooring laid across the whole of the basement level. We had water coming in around the chimney stack when we first moved in, so we had someone fit a lead flashing around the stack and they also refitted a couple of slipped slates. However, the quality of the job they did wasn't the best and although it solved the issue at the time, I'm not sure if it is now contributing to the second of the problems below. Finally, I suspect the floor level in the basement has been lowered (by about 10-20cm) at some point - I suspect this because we appear to have slightly more headroom at this level than our neighbours and the bottom step of the stairs down to the basement is clearly newer than the rest of the staircase.
Now to the problems.... Firstly, the basement. Unsurprisingly, the works done in 2009/10 didn't solve the damp problem. The vinyl flooring bubbled up and we removed it a few years ago, revealing an earlier (relatively modern) ceramic tiled floor. The paint also bubbled up in various locations and we were able to peel off most of the paint from the affected walls. The plaster has what looks like damp patches from floor level up to about 30cm above floor level, with evidence of salts leaching out of the plaster. However, when a surveyor put a damp meter on the walls recently, he said the walls (including the "damp" patches) were effectively dry. But, if we leave anything in the basement rooms, especially near the gable end wall, for any length of time it gets damp and eventually mould starts to form. Also, we recently left a (full) plastic bag on the floor for a couple of days and, when it was moved, there was film of moisture on the on the bag and on the floor where the bag had been. We want to re-fit the kitchen, repair the walls and put down a new floor but obviously don't want to waste money doing this if the underlying damp issue isn't resolved. We've had various solutions suggested to us over the years, including lining the basement level walls , various waterproofing treatments that could be applied to the walls and just accepting the situation and stripping the walls back to bare brick to let them breath.
The second problem is up at attic level. When we have heavy rain combined with a strong westerly wind, the inside of gable end wall in the attic becomes visibly wet in the triangle beneath where the two chimney breasts come together. This water then runs along the underside of the chimney breast and drips onto the attic floor, resulting in a damp patch forming on the bedroom ceiling below. Again, various solutions have been suggested, including rendering the gable end wall (which I'm not keen to do, especially as we're on clay and the house does move slightly with the seasons), and painting the end wall with a clear waterproofing treatment.
I'm not sure if the two problems are in some way linked - e.g. water penetrating the end wall and collecting at the bottom of the cavity? We'd really like to remedy the damp issue to make the basement level properly useable but can't afford to waste money on solutions that don't work or make matters worse. Any thought or ideas on how to resolve either of these problems would be gratefully received!
