Hi,
I've copied the post below from a thread on Diynot.com which concerns rising damp. I know some people think it doesn't exist and i was wondering if anyone here had an opinion on the points that are raised.
Hi,
However, there is one error in all this thinking, irrespective of the presence or not of a vertical wall covering, the mortar alone represents one continuous and uninterrupted material from ground to ceiling, the horizontal inter-brick mortar is in contact with the vertical mortar and as it is the same material it has the same capillary size. Imagine your house, you can place your finger on the pointing at floor level and run all the way to your roof without ever once having to cross another material, take your finger off the mortar or anything of the kind. What is it that prevents the mortar alone wicking water up from the base of the wall and saturating the bricks?
Amphibian makes a very valid point here i think, and one that i've been wondering about myself. Can anyone answer it?
I consider myself an 'RD doubter' as well, so i'd be quite happy for someone to successfully explain it.
As well as that, there is this:
http://www.palgrave-journals.com/jba/journal/v6/n1/full/jba201013a.html
If you read it, it seems Mr Ralph Burkinshaw has successfully (and surprisingly easily :? ) demonstrated damp rising through brickwork.
How has he done this when Jeff Howell couldn't, and that guy on the BBC documentary (he wasn't Howell was he?) claimed he used lots of different mortar mixes - did it never occur to him to try a lime mix?
I'm a bit puzzled as to how the debate can rage for so long only to (seemingly) be easily solved by an experiment i could've, with a bit of effort, carried out myself!
Surely there must be something a bit funny going on?
Thanks to anyone who takes the time to respond, or is it time to silently retreat?
Read more: http://www.diynot.com/forums/viewtopic.php?t=34549&start=180#ixzz20Qqrg07O
