Cubist
Anyone else having problems starting an old Briggs and Stratton 4 stroke engine using unadulterated E10 petrol?
For the mower and strimmer I've been buying premium petrol, which is still E5, so I've not tried E10 yet.Cubist said:Anyone else having problems starting an old Briggs and Stratton 4 stroke engine using unadulterated E10 petrol?
Feltwell, I was assuming that Cubist was talking about fresh fuel in the mower, but you are quite right about the risks of the petrol being stale.Feltwell said:I hear that E10 doesn't last as long as E5, so if it's been hanging around for a while it might be stale.
That said, my old Briggs & Stratton mower seems to run on any old rubbish. I stuck 15 year old petrol in it once, drained out of a motorbike, and it didn't complain.
paulc said:E10 petrol can (and will) attack certain types of fuel hoses along with some of the plastic/rubber components inside a carburetor. Newer engines should be OK as ethanol additives have been around fro several years now.
I had to strip a whacker plate than had been left standing for a long while - All the jets and main tube had to be removed, then soaked in carb cleaner. Still had to attack the built up gunk with a fine needle to clear the holes in the jets. Should have replaced the hoses & fuel filter while I had the thing apart. It now needs stripping again and cleaning..
worms said:Cubist, that sounds like a good result! I wonder if it is worth cleaning out the tank and the fuel line? ...or is it simpler just to take off the float bowl every so often and clean it out there?
worms said:Cubist, if it is one of the B&S plastic carburettors or one with a plastic diaphragm, you would be wise to have a replacement diaphragm kit on hand before you dismantle it. Even a slight softening of the carburettor diaphragm can be enough to mess up the fuel/air mixture.
Cubist said:To my mind its only worth flushing the tank and fuel lines if the fuel has been polluted with something that may damage them or the engine components.
