English Heritage have this guidance document written in 2016 which I've read a few times now, and wouldn't mind discussing its technical accuracy if anyone here has any direct experience or any expertise in this subject.
The document discusses mineral wool (as well as glass wool) and has what reads to me as a negative tone towards mineral wool and a very positive tone towards natural fibres. I'm curious if this is justified. I've spoken to a few installers that specialise in heritage buildings, and tried to speak to a few heritage experts and mostly get contradicting information.
From my research there appears to be a lack of case studies, lab testing and scientific literature on this topic.
So a break down of what the document says:
I would question describing mineral wool as air and moisture permeable to a degree, as they are equal in air and moisture permeability to hemp and sheepswool and significantly more so when compared to woodfibre (5X if I recall correctly).
Mineral wool is not hygroscopic so any leaks or significant condensation may cause cold bridges. But, natural fibres if wet will also loose their insulation properties, the only difference being that small amounts of water can spread through natural fibres so the impact is shared over a larger area.
Again true. But this requires the condensation or leak to be adjacent to vulnerable fabric. With a well ventilated space below, any condensation forming within the mineral wool will just dry out. If the space below is not well ventilated, then over time, both mineral and natural fibres will become wet. Natural fibres will have an benefit in intermittent edge cases.
Very true
The bit not mentioned here is the vulnerability of natural fibres to pests, moths and rot. Yes these materials now have much better artificial protection, but do we have the data to know that these protections last for decades?
Mineral wool has been around since Edwardian times and we have case studies of rockwool that's 50 years old that hasn't degraded at all. Longevity is really important, because if we need to go back in 20 years time to replace insulation that's a very significant negative against materials with limited long term testing.
Ok, so EH have concerns around mineral wool on suspended floors.Perhaps the most common materials used for insulating floors in existing buildings are fibreglass and mineral wool, primarily because they are cheap, easy to handle and convenient to install. However, they are not necessarily the best materials for the job, even though they are to a degree air and moisture permeable.
This is true.As the fibres of the insulation cannot absorb moisture, any condensation forming within the insulation zone will reduce insulation performance, increase the heat loss
and may also promote and sustain mould and rot in adjacent vulnerable fabric.
It's not clear if HE means the vulnerable fabric or the insulation here, however, with persistent moisture, mineral wool will not break down, but natural fibres may.Eventually, with persistent moisture, these materials themselves can start to break down.
They also need to be carefully handled by those installing them, and protective clothing and dust masks need to be worn.
Very true
So this is HE's claim.The most appropriate materials for older buildings currently available are those based on natural fibres, such as sheep’s wool, hemp fibre, cellulose fibres (derived from recycled newsprint) and wood-fibre board.
This is also true for mineral wool. The slight exception is the diffusion part, but this can be managed by having a well ventilated space below. Mineral wool has the benefit that if saturated from a spill, water will pass straight through, allow it to dry out much quicker than natural fibres can.’Natural’ insulation materials have the ability to ‘breathe’, allowing both air and moisture vapour to pass through slowly, thus minimising and diffusing the danger of condensation.
Again true, but it's describing a really niche occurrence where the benefit can be realised.Unlike artificial fibres, the material itself can also absorb moisture and release it again when the air is drier. This buffering effect can help to reduce the risk of condensation when there are rapid fluctuations in temperature or humidity.
