mostly_wrong
- South East
Hi all,
Sorry for another floor insulation thread! I have an 1880s semi, solid wall property with most of the ground floor suspended timber floors. I was primed to have a go at insulating them figuring that this would be a reasonable return on investment to do myself, however reading through the ecological building systems guidance on 'best practice' it notes PIR's "...its inability to enable vapour to be absorbed and gradually dispersed".
I would usually go for something like wood fibre, but the thermal properties of PIR can't be matched, as i'm only working with 2x4 joists so only looking for c.80mm of insulation supported by battens with a vapor control layer over the top. The fact that it's best practice guidance on a website trying to sell me something else makes me a bit skeptical, maybe i'm too cynical. I accept it will be a pain to cut to size but the point around vapor permeability worries me more. Does anyone have any direct experience of the long term impact from doing this?
My floor is pretty standard: it's a small ish void over soil solum with 2x4 joists held up across two sleeper walls. At the moment I just have the original boards covered by a t&g board which i'm going to replace afterwards.
