Hello,
In June of last year I purchased a building built in 1830 and have been gently stripping the layers of wallpaper back to begin renovation which I am hoping to do myself with a little help from friends and builders - only where necessary.
The house was built in 1830 it’s a 9inch brick single skin construction, but has had very little done to it in the meantime. From around 1970 (ish!) onwards the fireplaces have not been used and there has been no central heating or insulation. The original lime plaster has been buried under layers and layers of wallpaper including some pretty industrial vynl wallpaper that had meant the lime crumbles away completely along with the wallpaper as you remove it.
In an ideal world I would repair the laths, many of which are un-salvageable and redo all of the walls in lime plaster. Unfortunately my budget won’t allow for that for now so hoping to put up insulated plasterboard with a vapour layer straight onto the batons.
My question really (at last! Sorry for the waffle) relates to what I should do about the external wall. The building is end of terrace, the external walls were originally lime but have at some point been re-rendered in cement. The internal walls on these sides are very damp, and when I have stripped them back the lime mortar on the exposed bricks is very deteriorated.
I know the sources of some of the water ingress, cracked window sills etc and there is a large-ish crack on one of the exterior walls that I will need to get some assistance in to tie and patch asap. Should I also be factoring the need to chip off the cement render at the same time, in order to replace with lime render?
I know that in a perfect situation this is what I would do, but given my budget is extremely tight, can I get away with keeping the existing cement render, patching it and repainting, so I can get on with putting up the internal walls?
I’ve done quite a bit of research, but I’m a bit lost at this point and would be immensely grateful for any advice anyone can offer!
