This is a long way off for me, but I'm wondering what people's thoughts are on the following.
We have a coach house (a third of the same building, shared by three neighbours) which is on two levels, all pretty original (late Victorian), although there isn't much to it. It has cobbled floors, a single brick thick wall on one long side and a stone wall on the other. The house used to be owned by a butchers and I'm guessing the meat hooks hanging from the joists of the first floor are probably original. There is an exterior door on the first floor with the now sawn off beam that would have had a pulley on the end for getting horse food or whatever they used to store up there, up there. One set of doors on the long brick side has been bricked up and and up and over garage door put in the gable end. Theres' a disused chimney in one corner, and the stack remains.
Anyway - I have plenty of (automotive for now) projects to get on with in there, but they would benefit from a) a clean level floor and b) some wall and floor/ceiling insulation. E.g. I can't spray paint a thing in winter, which is the best time to be tinkering in the garage! The cobbles make life a bit more difficult in terms of moving heavy things around with any precision. And given the limited space most of my heavy tools are or will be on wheels.
I am thinking along the lines of going making the ground floor more useful by: floor levelling via a very shallow timber deck of ply on treated battens, and dry lining via some thing stud walls and plasterboard. This would make a lovely workshop/garage, but I'm torn a bit considering how much character I'd lose in the process. The aim would be to make everything reversible, hence the floor not being poured at all. I think I could insulate the ceiling without losing the meat hooks as the joists are 9 or 12".
Just wondering what other peoples thoughts might be in a similar situation and when or where you draw the line regards retaining character..
