livias said:Contrariwise!!!!
IMO full length curtains look nicer then short ones and they are much better at keeping the room warm by blocking off the cold spot that is a window. So I never put radiators under windows.
Flyfisher said:... the best way to minimise the sort of damage mentioned above pipework to be routed rather than just let the installers decide (which applies to the rads as well really, as Livias points out), because they'll have the tools to go through anything in their way and will probably be concentrating on the most convenient route for them rather than being too concerned about the building fabric.
Owain said:Microbore radiator pipes can be 8mm so thinner than some electric cables. You need an individual feed to each radiator from a manifold, though.
jsmac said:... you mentioned the minimum recommended humidity for joinery. What is the amount of humidity that is considered too much? ie. where wood will begin to rot?
88v8 said:You won't hear any noise from Flyfisher's 3" pipes, which I would guess were part of a thermocycle system with no pump at all.
Flyfisher said:The original (mostly large & very heavy!) radiators seemed to be connected 'in series' rather than across flow and return pipework, so perhaps that's what you mean by a 'thermocycle' system?
Had a 34 Lanchester /quote]
A classic car fan too, Ivor?
Cubist said:A classic car fan too, Ivor?
