Flyfisher
- Norfolk, UK
Last year I finally started working on the last room in the house that needs total renovation, so the end really is now in sight or at least coming into view (apart from a lot of decorating, but somehow I manage to ignore that particular aspect of things).
The floor is somewhat odd, being half pamments laid on earth and half suspended floorboards over a cellar. The floorboard section was also higher than the pamments, with two small steps down to the pamments, effectively dividing the room. The pamment floor was below the outside ground level, which unsurprisingly had caused penetrating damp (goodbye skirting boards!). I had already reduced the external ground level as far as I reasonably could, given the shallow foundations, but it was still level with the pamment floor, so not ideal.
A plan was hatched to lift all the pamments, lay an insulated limecrete floor with UFH (based on the Mike Wye foamed glass model - https://www.mikewye.co.uk/limecrete-floors/) and replace all the original pamments. This would raise the new floor above outside ground level and level with the floorboard area. UFH was proposed as I didn't really want to clutter the walls with radiators. LBC duly granted, this work started late last year and the floor was left to thoroughly harden.
I'm getting to my question :wink:
The pamments were originally laid tightly adjacent to each other with no defined grout lines. I don't really know if anything specific was originally used between the pamments or whether there was just a build-up of general muck over the decades (centuries?), but whatever it was was not loose, all the tiles sat firmly in place and nothing was sucked up when vacuuming the floor.
Naturally, I want to re-lay the pamments as they were and have been laying them as close together as possible, which is perfectly fine although there are naturally a few small gaps between them. And therein (finally!) lies the question - what to do with these small gaps? - I'm considering a few options:
1. Just leave them as they are and let time do its work, clogging them up with the inevitable 'muck' that floors attract.
2. Fill them with kiln-dried fine sand by brushing it over the surface
3. Fill them with a dry mix of kiln-dried sand and NHL lime in the same way
4. Fill them with just dry NHL lime in the same way.
I've not seriously considered attempting to grout them by brushing over with a wet lime mixture because of the risk of staining the porous pamments, which might be possible to remove with brick acid but even so would take ages. Similarly, I've not considered trying to hand-grout using a wet mix because it would be nigh on impossibl. I can't even get a knife edge between most of the pamments so even laborious hand-grouting would result in significant spillage and therefore staining and therefore laborious cleaning.
Option 1 seems a bit of a cop-out. Option 2 would likely be undone the first time the floor is vacuumed. Option 3 seems feasible and the hope is that residual damp in the floor and pamments would cause the NHL lime to harden over the next few weeks, which would eliminate the vacuuming issue. Option 4 is there simply because I'm wondering if there is any need for sand at all.
So two main questions really: 1 - have I missed any other options? and 2 - what does the panel think would be the best option?
