Period_Property_Noob
- Ayrshire
Hi folks,
Long-time lurker, first time poster.
So I've got a bit of a pickle - a builder ignored a lot of my requests on a project and I'm trying to gauge how worried I should be. I don't work in the trades but I've done a property reno in the last few years basically just using the internet for research.
I've got a side porch on the side of my 1850's miners cottage, which is over two levels. The house is on a hill, and Ground floor is partial basement, first floor at street level. Construction is sandstone masonry at ground level, transitioning to solid brick.
The porch previously had 5" thick sandstone slabs for a floor, supported by a very rotten roughed out tree trunk that was not visible . Ground floor had a very old concrete floor in very poor condition. Previous owner fitted a bathroom (poorly), which had multiple water leaks that were leaking for an unknown period of time probably in the order of years.
Owing to the longstanding issues we decided to rip the old sandstone floor out and replace it with a joist floor, fitted to the walls with a large timber joist bolted to the walls
Three issues - that I raised with the builder at the time, which are now causing me increasing worry:
1) The builder patched a lot of the damage on walls with what looks like a very strong sand/cement render. There's probably a band running around the perimeter of the room 30cm high where the existing lime plaster has been replaced with a sand cement render to make the walls flat. I offered him a bag of NHL 3.5 that is very well sealed and has been open less than a month but he declined.
2) The builder used ordinary building screws rather than what I've always known as 'joist nails' (twisty galvanised nails). When I challenged him, he placated me with a few extra nails in the empty holes in the joist hangars from his nail guns. Positively, the floor has been very conservatives constructed with respect to joist spacing (small span < 3m, joist spacing < 400m).
3) There's no DPM between the wood and the cement / masonry bedding. I'm particularly worried about damp bridging into the wood and causing it to rot.
How worried should I be?
The original plan for the room below was to insulate the joists with some vapour permeable rockwool type insulation, wrap the whole porch in wood fibre EWI and then use the basement as a plant room.
Thanks in advance, etc.
