middi said:You cannot have uderfloor heating and expect to have breatheable floor as originally intended. CORRECTION !!!, you can, but most of the heat will travel in the opposite direction . YOU must have one or the other, anything in between is a compromise of total efficiency if you decide to use underfloor heat
Middi
250mm total sounds too little to me. When I was looking into LECA floors, I was calculating something like 430mm if I remember correctly. (For comparison, our floor is base layer, 150mm concrete, 100mm Celotex, underfloor pipes, 75mm screed.) BC will want thermal figures for your floor so that will probably dictate what thickness is required.robgil said:It looks like LECA might be the only option, UFH might go down but at this point in time I doubt it will, cash flow will dictate this.
so, 100mm loose fill leca, 100mm hempcrete slab and 50mm lime/sand screed, all using nhl3.5.
Does this sound about right?
Feltwell said:If cost is the issue with installing UFH, can you not just put the pipework in for now and leave the manifolds & ground source heat pump setup or boiler until a later date? I'm presuming the pipework is not the expensive bit.
