Feltwell
- Shropshire, England
Very pathetic to post this up really.....
To treat myself as a result of getting a new job, I've decided to buy myself a slide compound mitre saw, as currently I've only got a small and cheap chop saw. Whilst I like Makita stuff a lot, I don't like it enough to spend the £400 - £600 that a decent one would cost, so it's time to look at the cheaper options.
Which brings me to the choice I have:-
Spend £200-ish on a very good quality, but old fashioned design, saw from Axminster very similar to the one below. Lovely saw, I can get one that's been a customer return and has had a simple fault fixed. From the reviews it will outlive me. Dust extraction is poor, no laser guide, neither of which bother me that much, but it will only cut wood up to 61mm thick. The quality of it should mean that it cuts accurately.
http://www.axminster.co.uk/axminste...itre-saw-prod32404/?searchfor=mitre saw quiet
Or - spend a similar amount on a saw which is probably not such good quality, certainly will be noisier, but which will cut up to 110mm thick. It may not be quite as accurate though, certainly on the pre-defined angle stops.
http://www.sipuk.co.uk/tools/info_SIP01502.html
I've got a SIP router and I'm very pleased with it - it's not top quality but for amateur use it's plenty good enough, which is what I wonder about the saw above.
How often will I need to cut wood between 61 and 110mm thick? Not that often really, most will be below 61mm. But it'll happen often enough that I'll curse!
I had a sliding compound mitre saw years ago, but it was so cr@p that I got rid of it very quickly - I can't complain too much, it was a freebie from my work at the time, but it was so cheap and nasty and wobbly that the cuts it gave were horrendously inaccurate.
So what do you reckon? Medium-ish quality and more features? Or "outlive me" quality but less features and a bit restricted in use? Anyone got a sliding mitre saw?
