dames83
- Herefordshire
Hi,
I've delved into the confusing subject of internal wall insulation.
I have a stone property, which I am planning to insulate the inside of the external walls. I would like to use breathable insulation and lime plaster.
I've considered hemp lime plaster, but worry that it won't be very insulative.
My thoughts are to go with the following, although I've not come across anyone using the same method:
25mm batten to stone wall
25mm Rockwool between battens
15mm wood wool board on battens
2x Lime plaster skim with render mesh embedded in the first coat.
Is this a reasonable solution?
Any thoughts/advice would be most appreciated.
