As the title suggests how is the return of the insulation on the inside/party walls tackled. The following you tube recommends a tapered insulation on the internal walls to about 600mm.
Other option would be to have similar thickness of insulation to that applied on external walls to about 600mm on the adjacent internal walls.
This would look a bit odd. Rooms with stepped walls
For those members who have gone down the rout of IWI - what did you do with the returns, if anything?
