ajay16
- Lincolnshire
I'm about to insulate a room in a circa 150 year old outbuilding, lime mortar and brick construction, walls are about 30cm thick. The size of this part of the building is 10m sq, nothing huge.
I'll be using Celenit acoustic wood fibre boards on warm battens as the finished walling to keep it breathable, and sheeps wool insulation behind that.
Do I need a hybrid type VCL membrane sitting behind the Celenit boards before the sheeps wool?
I wouldn't have thought so as the whole system will be breathable anyway, with low moisture levels in the room, but any thoughts?
The room is going to be used as a workshop/studio/office.
Two small UPVC windows are going in with trickle vents.
Wooden main door with half height single glazing.
Ceramic electric radiator for heat.
DPM is already in the concrete floor (put down before my ownership)
Floor will be XPS, hardboard, carpet tiles.
So the build up of the wall would be:
*Outside*
-External lime mortar/brick wall
-Sheeps wool insulation
-Celenit wood wool boards
*Inside*
*Outside*
*Inside*
