Following on from a similar thread. I will be ordering pallet of St Austier NHL 2 lime and want to make good use of it.
Can you please advise on the ratios required to make lime plaster.
Will be using NHL 2 product and I suspect will require Yellow building sand. Have I missed any other ingredients?
Also insulated lime plaster came into mind. If I was to add hemp or cork to the above lime plaster mix to make insulated lime plaster.
Does anyone have any experience on the thickness of plaster application required to solid 9 inch brick to infer sufficient insulation properties say on par say with adding about 50mm of flexible woodfibre material?
As always, many thanks and extremely grateful
