Lacan07
Hi All
I'm in the middle of renovating a very old house that used form part of an early 1800's hop farm. I've been working on the upper floors and I'm now at the point where i need to skim the lime walls so my electrician can return to energise the upper circuit.
Whilst I've already lime plastered the bare brick wall under the stairs using Lime Green products (emergency due to electric meter relocation) I've decided to bring in a young plasterer to help me with the upstairs skim. He's new to Lime but keen to help. I've almost finished the prep work and we are currently at the planning stage and would appreciate any advice.
All walls have the original polished lime plaster but there was a bit of 'fall out' when removing the skirting board from the lath & plaster stud walls so I've had to replace some parts with plasterboard and the odd screw/washer to tighten the existing plaster back to lath. I've scrim taped all the joints and the joints between the plasterboard and existing lime plaster which I will prep/fill using a slightly thinner multi finish (gypsum).
But my main question is what type of lime to use and whether I should 'prep' the walls first with a thin mix of Lime putty and water (limewater) or just wet the walls to control suction?
What concoction for the skim?
1. A ready made product like St Astier Ecomortar R100, can be used on almost any surface but the most expensive option?
2. A ready mixed lime putty, just need to knock up?
3. Or should I make up my own using NHL 2 and fine sand, and if so what mix?
Apologies for all the questions, any experience from fellow forum members much appreciated.
Thanks. Paul
Thanks. Paul
