A
Anonymous
Guest
I've been looking through these pages gathering info on lime use on the brickwork for older properties. I thought I'd grasped it and was ready to tell any builders I spoke to that "I want it done in 1 part NHL 3.5 to 3 parts sand, etc". I then took a look at an article elsewhere on the site and I am confused again. The article, by Jeff Howell, says:
Lime mortar is easy to make and use. The only problem is trying to find a bricklayer prepared to use it. There is a common myth amongst builders that lime and sand mortar will not harden unless cement is mixed into it, and a common myth amongst building conservation experts (who really should know better) that the only suitable material is hydraulic lime. In fact, hydrated lime - available in 25 kilo sacks (costing 3 to 4 quid)from practically every builders' merchants in the land - makes a perfect lime mortar for bricklaying and pointing. Mix it with washed coarse sharp sand, around 1 part lime to 4 of sand. Keep it wet in tubs or buckets, with an inch of water on top of it, and it will be ready to use whenever you need it. No need for expensive tubs of slaked lime putty, or expensive sacks of hydraulic lime. And definitely no need for cement.
What is the general consensus on this? For example, if I had a small patch of re-pointing to do could I go with the above advice? If so, how is it mixed and prepared?
Many Thanks
Many Thanks
