Rawler
- Darley Dale
Hello everyone,
I'm insulating a loft room roof space (ie in the rafters) and going with a breathable system, keeping an airgap below the roof membrane the first layer beneath this is to be Sheepswool (50mm), then likely Woodfibre board. I'm aware of the calculations and appreciate it won't hit building regs U values, but it should be manageable. The main risk is that there is a roof leak and the wool gets wet to a degree where it slumps and blocks the air gap. I appreciate it can absorb and release moisture to a degreee without any effect on shape, but I am working to a tight air gap 25-30mm so not a lot to work with. Has anyone else used this technique? Is it an unnecessary concern? Should I look at cross doweling or netting it from above? I have trialled the latter but it's not taught enough. Any system needs to connect into the side of the existing rafter.
Many thanks
Many thanks
