We will be rendering the parapet wall with Best of Lime's Rendercote. The cement render that was covering the bricks previously made such a mess that re-rendering the top 800mm or so of this section of the front of the property is the best solution (completely rebuilding the parapet wall was not a viable option).
I will be fixing the drip bead and stop beads to the wall with stainless steel coach screws and plugs but may need to use a small amount of mastic to get the beading in place above a window arch before fixing with screws.
Can anyone recommend a suitable mastic for this purpose? As I'm sure you're all aware there is almost a limitless number of these grab adhesive products so if anyone can point me in the right direction it would be most appreciated.
Many thanks.
Many thanks.
