malcolm
& Clementine the cat
- Bedfordshire
What type of mortar would you use for a roof verge?
My new roof is in slate or peg tile (depending on which side of the roof you are looking at) and the tiles now extend around 50mm past the gable with a cement board under cloak. On the old roof the verge mortar had clearly been repaired many times due to cracking and falling out. The repairs were largely in cement and would have needed repairing again had we not lifted and replaced the tiles/slates.
I would have thought a relatively soft lime mix would better resist cracking if that is the problem more than erosion. NHL 3.5 with course sharp sand maybe. The roofer has agreed to use whatever mix I specify in lue of guarantee, or will do it in whatever readymix they normally use (presumably 4:1 sand cement).
Also any tips on bedding ridge tiles? I'm tempted to let them do what they do for the ridge tiles as it doesn't really matter if the mix cracks.
He is a decent roofer. I'm quite pleased with his welded leading, but might be stuck in the modern age a little with his cements.
