topdog91
- NW London / SW Herts
Hi all, first post so please be gentle.
We're considering buying a circa-1900 Edwardian cottage. It is not listed, but it is in Green Belt, and we have submitted a pre-planning application for a modest rear extension.
We are new to traditional buildings and are finding the advice quite confusing. Some people say they understand period properties, breathability and damp, but then quickly talk about chemical DPC injection, damp specialists, gypsum plaster, modern tanking, etc. Others say old cottages should be treated very differently, with focus on ground levels, rainwater goods, ventilation, lime plaster, breathable materials, roof/chimney defects and undoing bad modern interventions.
The cottage is one of a small row next to an old farm. It has clearly been altered over time. There is an awkward later first-floor/box-room extension where the roof geometry is poor, with intersecting roof forms/gables intruding into the upstairs space. There is also a collapsed lath and plaster ceiling in one bedroom, possibly where a chimney stack or chimney breast was removed or badly supported.
It also has old private drainage/cesspit arrangements. The other cottages apparently have treatment plants. There are possible damp-related issues, including external ground levels/materials and a black painted material at the base of some walls. We do not yet know whether the damp is due to real structural defects, trapped moisture, neglect, bad modern repairs, failed rainwater goods, poor ventilation, or something else.
We have had a practical builder look at it and he seemed to understand the roof/upstairs issue well. His suggestion was that if we extend, we should also take the opportunity to remove/rework the existing rear roof and properly solve the compromised bedroom/box-room layout. That made sense to us. However, he also mentioned damp injection, which made us nervous, as we keep reading that this can be over-prescribed in older buildings.
At the moment we are trying to work out the right team and sequence before committing too far. Our current thinking is:
What would experienced period-property people suggest?
Specific questions:
Any advice would be much appreciated, thanks in advance and good to be here.
- Get a surveyor who genuinely understands traditional buildings, damp, timber, breathability and old materials. (We've even had conflicting advice about whether a 1900s Edwardian cottage requires such a surveyor - one friend said any surveyor will do as they aren't old in the grand scheme of things.)
- Get a structural engineer specifically to look at the roof/chimney/ceiling collapse issue.
- Get a drainage camera survey for the cesspit/septic/treatment plant situation.
- Use a competent general builder for the main refurbishment and extension.
- Bring in heritage/traditional-building advice for the sensitive parts, such as damp diagnosis, lime plaster, breathable finishes, high external ground levels, and undoing inappropriate modern repairs.
- Avoid chemical DPC injection unless there is a proper diagnosis and a convincing reason for it.
Specific questions:
- How do we identify a surveyor who genuinely understands traditional buildings, rather than just saying they do?
- Is RICS Level 3 enough, or should we prioritise a conservation/traditional-building specialist?
- Is it sensible to use a normal builder for the main works, while taking specialist heritage advice on damp, plaster, breathability and old fabric?
- Is chemical DPC injection ever appropriate in a cottage of this age, or should we treat it as a warning sign unless very clearly justified?
- What should we do before purchase to understand the collapsed lath and plaster ceiling and possible chimney/roof issue?
- How would you approach valuation and offers when the real scope of work is still uncertain?
- Are there any particular red flags in a circa-1900 cottage that we should be looking for?
- Any recommendations for surveyors, engineers, drainage people or builders in Hertfordshire, North London or southwest Hertfordshire who are good with this sort of property?
