Sam W
- Shropshire
Hi, I'm replastering a stone wall with NHL based plaster (Lime Green Duro). Web advice on plaster recoat times is anything from 2-10 days, although 3-5 days is most common. My vague memory from doing another room is that I got the best results from leaving about 24 hours between coats, but it was a while ago and I'm wondering if I'm misremembering.
Any thoughts? If it makes any difference, final coat will be done using a putty based lime plaster, which I've found gives a nicer finish than the NHL based finish plasters.
