Hi All
Wondering if you can help as I can’t find the answer.
We’re due to move in to an Edwardian terrace which has lime plaster walls on the original part of the house (no damp recorded).
Previous owners used Little Green Intelligent Matt Emulsion (not the Absolute version which I understand is more suited/has a lower SD rating)
I’m wondering whether we can paint over this using the Little Green absolute Matt emulsion or it’s advised to remove paint first. I would prefer to remove if it’ll cause issues but thought I’d check if others took this approach.
Concerned with causing potential damage to plaster by removing it if using steamers or paint peelers.
Cheers
Cheers
