I’m not sure if I have a correct understanding of the term “pozzolans” but would I be correct in thinking that these are materials for example brick dust, which when added to a sand and hydrated lime mix or to a sand and lime putty mix change the properties of that mix to that of hydraulic lime or feebly hydraulic lime? Indeed isn’t hydraulic lime just hydrated lime with natural pozzolans in it? My main concern is that a pure 3:1 sand and hydrated lime mix or sand and lime putty mix can be very light in colour when cured and even glaringly white despite having used a relatively dark concreting sand. On one occasion I found that my lime cured to a pink colour after having used a specified Westerham sand. I therefore sometimes find it necessary to darken the mix down in order to match up with old. In my case I found I could get the right shade of colour by adding a small quantity of coal dust into the mix i.e. tiny shards of coal that you find at the bottom of a coal pile which I broke down with a mallet. Would this coal dust be considered a pozzolan and if so will it affect the properties of my mix? Is there something else I should be using instead of coal dust to attain the right colour without affecting the properties of the lime? I had heard that iron oxide (rust) is quite good but again wouldn’t this also act as a pozzolan? Sorry if I’ve got it all wrong and I’m just talking nonsense.
