youngy89
- Irby, Wirral
Hi all,
I’m just about to move on to my next job: preparing the walls ready for a lime parge coat, which I’ll then use to fix wood fibre boards to the internal face of an external wall.
Before I crack on, I’m debating what to do with an existing double-brick air vent that’s currently at head height. It lets a lot of air through, and given the room is only around 2.5 m × 2.5 m and will be used as a home office (no fireplace or solid fuel appliances), I’m wondering whether it’s actually needed.
We’re also replacing the windows, which have all failed, and the new ones will include trickle vents.
Given the small size of the room, the low moisture use (office rather than kitchen/bathroom), and the addition of trickle vents, do you think I could reasonably fill in the vent? If I did, it would be done properly — bricks laid in lime mortar, and the breathable wall insulation continued across the internal face.
Interested to hear people’s thoughts.
Cheers,
Tom
Cheers,
Tom
