I'm looking to buy a listed brick Georgian property with a brick (possible Victorian) extension, again brick.
The extension includes a Coach House, where the arch has clearly dropped at some point resulting in cracks on adjacent walls.
The survey suspected that some of the cracks could also be due to thermal expansion (old laundry boiler) but couldn't rule out a foundation issue, but the shape of the cracks didn't point to a foundation issue.
Looking at 20 years photos some of the external cracks were repaired a long time ago, so it doesn't appear to be new movement.
Cracks are parallel, vertical and up to half an inch.
Naturally the surveyor recommended getting a structural engineer out, but also to monitor.
Solutions could range from just filling with lime, or inserting helical strips.
If we go down the helical strip route do we need to avoid using the grout they provide. I believe this is epoxy based so will create a hard point and trap moisture.
We could lime them in, but I suspect this achieves very little.
Does this mean helical strips shouldn't be used on period properties?
Another thought, would helical strips trigger listed building consent?
