Hello,
I'm close to buying a G2 listed house with mostly wooden single glazed windows and a few cheap nasty PVC windows at the rear. It's a very handsome Georgian property.
Most of the windows appear to be circa 1990's (from talking to neighbours) single glazed wooden casement windows (non sash). Unfortunately there is only one window that is what might be a historic sash with it's iconic six glass panes per casement, with old looking wobbly glass (annoyingly one pane is cracked, assume these can be sourced somewhere to look like original).
When walking around with the surveyor he was suggesting repair costs of around £1500 per window to replace rotten sections of frame (bottom of window). There are probably about 5 windows to do, with the rest just needing minor maintenance.
I'm fairly handy. I fitted my last kitchen for example, using a jig and router to create a seamless joint on the laminate worktop. You take your time and with the right tools it came out fine. Built the odd cabinet, shelves etc. I'm more mechanically minded to work on cars, welding etc, but comfortable trying anything, apart from plastering (bad memories, although I will be trying this again soon with more realistic expectations).
So I have this possibly arrogant, maybe naïve idea that with a router table (this has nothing to do with the fact I want an excuse to buy one) and a planing table (again, always wanted one) I could make replicas of the rotten parts and reassemble. I don't know how they are held together, but would probably just use a simple biscuit joint. I'd start with the 1990's windows as there is no historic value here anyway so I wouldn't feel the need to consult the CO and would do a like for like repair. When experienced and confident I would work on the historic window.
By which point, would it be that naïve to assume I could build my own windows to replace the PVC (with CO/LBC) I was thinking I would build one as an experiment, and use it as a sample of what I want to use for discussions with the CO. Built to match the only historic window. Not needing FENSA on listed building makes this all possible in theory.
I'm probably going to try some of this regardless of the responses and sound advice I get as I like learning things the hard way. You learn a lot by failing.
I was just wondering how many out there do this type of repairs themselves to get a sense of how realistic my plans are?
