Rawler
- Darley Dale
Dear Community,
I need to repoint a gable end wall. My house is on a hillside in Derbyshire, but the next building is only about 1.5m away so it's not hugely exposed, although there is potentially a wind tunnel effect (?). I am well versed in the different types of lime mortar, necesary types of sand and have worked with both lime putty and NHL based, but I'm getting conflicting advice between books, local heritage tradesman, AI, and even SPAB etc. My stone is Gritstone, so relatively hardwearing.
On one hand most practictioners and vendors seem to advocate NHL 3.5, but could be due to the ease and speed? Reading "Building with Lime" (Homes and Wingate), it advocates that the lime mortar should always be stronger in the middle of the wall than at the sacrificial pointing (edge). Given the building was built at the end of the 19th Century its likely just (air) lime putty mortar (not NHL). So putting any NHL to repoint will be stronger than the existing lime mortar and could cause the stone to degrade in time. I guess the question is as long as the NHL is weaker than the stone the pointing won't cause the stone to spall, so should be fine? But I can't get away from the fact the using putty based to match the existing will allow the whole wall to work better. Has anyone had any direct, non biased experience of this and seen the effect of NHL versus putty on external semi exposed walls over 20 years? I'd prefer to do it well and once.
Many thanks
Many thanks
