Feltwell
- Shropshire, England
Here at Feltwell Towers, we're lucky enough to have nearly all the original windows, which are mostly box sashes. Single glazed of course, and gradually being restored and draughtproofed by yours truly - which makes a huge difference, not just for draughts but also for usability - the windows don't rattle and glide open and shut on the draughtproofing brush seals.
Keeping the original windows is a must. I could replace the sliding sashes with new ones with double glazed units in, but I'm not keen on that for a number of reasons - weight of windows and difficulty of accommodating the larger sash weights, loss of original joinery and glass, chunkier mouldings to hide seals, future failure of DG seals, and DG units just never look quite right to me.
I do though like the idea of anything non-intrusive to make the house warmer, and cutting down on condensation on the glass - which of course the draughtproofing makes worse!
Most secondary glazing systems seem to consist of an aluminium frame with the sliding vertical sashes holding the secondary glazing - this kind of thing:-
https://www.duration.co.uk/Secondary-Glazing-Vertical-Sliders.asp
https://www.gsecg.com/products/vertical-sliders/
These look very effective and I've stayed in hotels with them fitted many times - they seem very good, jury is out on the aesthetics but I think I could live with the right system, fitted well. Alas, they only really seem to suit windows that are sat back from the inner wall surface in a reveal. On my windows, the inner face of the sash box is flush with the wall plaster - fancy architrave covering the gap - there is no reveal at all. The only way to fit one of these frames would be to face fix it to the architrave, sticking out into the room, which would look awful.
I've tried polycarbonate sheet ("Perspex") fixed with magnetic strips - just didn't work for us, they rattled badly in high winds and were a pain to store when taken down, which you had to do to open the windows. I persisted with different options but finally admitted defeat.
Tonight I've spotted this frameless glass shutter system which looks intriguing. Certainly very subtle in appearance, especially with the hinges lined up with the meeting rail. Looks like they mount to the staff bead, so lack of window reveal is not a problem. They won't have a good seal to the window or to each other at joints - the sliding sash type above must be much better - but I reckon they'll still have a benefit, those who've got wooden shutters say how much they help keep the heat in and their seal is no better. Has anyone seen them in use or spotted any alternative types of system?
http://glassshutter.co.uk/index.html
