We have removed the old render from two elevations of our property, replaced a couple hundred perished bricks, repointed one elevation completely and repaired the pointing where necessary on the other elevation. We found that it has been necessary to make a call on where to stop removing damaged bricks. When you're up close and looking at them one by one many of them look a bit knackered compared to a new wall so we have had to decide where to stop replacing them or reversing them as we have have fortunately been able to do for many of the original bricks. The walls are solid now and in better structural condition than they have been in probably many decades. However, there will no doubt be some bricks that will have lost some of their outer face and so be more porous than they would have been originally. The wall that suffered the most and was in worse condition by far is made of softer red bricks so I would expect those bricks to absorb moisture more readily.
I am wondering if anyone has opinions or experience with using silicone-based masonry sealants. We collected some render from Best of Lime last week and were speaking with them about a sealant they sell which claims to be breathable but allows the masonry to more effectively shed water. (ie. water vapour passes through but liquid water is repelled). Beeck manufacture a similar product and Mike Wye also sell something similar. I presume they all consist of a similar chemical composition. The data sheets suggest that it is only slightly less vapour permeable than lime wash but I really don't know what to think of that.
I guess what I'm wondering is if using a sealant like this on the masonry is a sensible or terrible idea. They make bold claims but I have no idea how long they've been available for so if there is in actuality any long term real world testing.
Has anyone come across these treatments?
Thank you!
Thank you!
