Londonterrace
Hi all,
Another request for advice. Apologies for another damp question…I know you get an abundance.
My house is a Victorian terrace. A few days ago we noticed the downstairs floor was ominously springy and lifted the floorboards. The springy area is in the back reception room, near to the back wall. Half of this wall has the side return on the other side and the other half has the kitchen.
About half of the joists seem to be resting on a piece of wood running perpendicular to them (so in line with the floorboards). This is turn is resting on brick piers. The piece of wood is damp to the touch and rotting. After some time with bowls under our plumber’s shocking joins, I don’t think there’s a plumbing leak. (We did find a bonus unrelated plumbing leak further down in another part of the wall though. Such fun!) The wood is wettest at the bottom and looks salty where it touches the brick piers which to me suggests it is soaking water up through the piers?
I don’t think the ground level is too high (certainly not touching the wood) and I can see through the two air bricks in the part of the wall that communicates with the outside.
What’s this piece of wood called and can I stop it drawing water in through the brick pillars (if that is indeed what is happening)? Does it need to be replaced with metal?
Why has this just started happening? I don’t think the floor was springy a year ago.
Thanks for any help!
Photos going from left to right along the wall:
Now we reach the bit that was spring and where the beam looks most in trouble. Despite the suspicious proximity of the plumbing, nothing coming from the pipes:
It ends and the remainder of the joists touch the pillars directly, or at least hang on scraps of wood on the pillars:
Then this second joint is leaking (very slowly), but hasn't made the joist above it or the ground wet, just the pillar it is above. So I think an unrelated problem:
