Apologies in advance, I imagine this is a recurring query, though much of the advice I seem to be finding is wildly conflicting and wanted to check my thinking before making an expensive mistake.
My property is a Victorian era, solid sandstone, end of terrace property.
Following damp issues due to chimney ingress along with lath and plaster bridging I have removed the plasterwork from the majority of external facing walls within the property.
I had intended to insulate these whilst the walls are off though have met a few hurdles.
Initially I’d intended to use insulated plasterboard, though the suggestion is that as this is not breathable it would result in long term damp issues. Though would have had the benefit of leaving an air-gap.
I’d then looked at mineral wool/lambs wool with a lime plaster coat. However, due to the available gap being limited, i.e. I can’t expand this or it would impact the cornices, I would be unable to leave the required air-gap. The suggestion being that without the air gap this will bridge and again cause long term issues.
So, from what I understand neither are viable long term solutions and that I would be best just re-plastering without any insulation? Colder, but with reduced likelihood of damp.
