johnobirches
Hi again,
To get a mortgage for our new old house, we had to have a structural survey - fair enough.
The surveyor pointed out some cracks and evidence of outward movement of the front wall away from the cross walls on the first floor (upstairs).
This is backed up by obvious cracks once we got the plaster off. See pics of before and after I raked out the joints.
I'm going to work my way up this crack removing stones and mortaring in new stones to both walls which overlap at the corner (using lime mortar by the way).
The structural surveyor pointed out in his report that the movement may have been very old and that lime mortar remains relatively soft and allows movement but then went on to recommend the fixing of L shaped metal straps up the inside of the corners where crosswalls and gables meet front and rear walls and also the fitting of L shaped metal straps at 1 metre spacing along the tops of 1st floor joists and up the face of internal walls.
We may be required by our mortgage lender to show that this has been carried out but I can't for the life of me see how I can get solid enough fixings into these rubble walls to make such a solution effective. The stones are too small to drill and in any case any drilling would just loosen them, and trying to secure fastenings into the lime mortar between stones would just be silly.
All I can think of doing is installing some of those cast iron plates on the front and rear outside walls which are joined by a long rod passing throught the whole house. [Anyone know what they are called and where to get them?]
Any other suggestions would be appreciated. The daft thing is that from the outside there is no noticable bulging or spreading of the walls.
We hope to make the upstairs ceilings vaulted which will have implications re: possible spreading of the upper exterior walls but maybe we could make that part of the solution. - Another topic required there though I think.
Cheers
John
Cheers
John
