Bayliss
- Bury St Edmunds Suffolk
Currently we use a medium size Franklin open stove in our living room, it burns logs or coal but is only slightly better in terms of heat value than an open fire. For this reason, and of course the current fuel cost, we have decided to replace the Franklin with a proper stove, one which runs with the double airwash to help keep glass clean.
Our living room is 12' x 16' + a 5' x 6' bay window. The walls are a mix of lath and plaster and gable wall of single thickness brick. Gable wall and front wall are exposed to outside whilst remaining two walls are internal. We would burn logs and then occasional solid fuel.
Kw rating requirement much appreciated. Thank you
