ash_and_iz
- Bristol
Happy new year all. Would appreciate any input the forum could provide on suggested fixes.
We have had some damp issues high up on an external wall that makes up a small bay window in back of our 1890s Victorian semi-detached. Investigating some potential causes and have pulled the moulding off the window to find just a massive cavity beside the window (pictures attached). There was debris and chunks of mortar/plaster like material and dust that I have cleaned out. This on the left side of the window and measure 35cm wide by 135cm deep. I assume it’s like this all the way around the window but want to have a plan before I remove anymore mouldings.
I’ve read enough of the forum to know that oakum can be used to caulk between to the window frame and masonry but seems like an ineffective solution given the size of the cavity. I have hemp wool insulation I have been using to insulate under the ground floor floorboards but just shoving some of that in there and covering with the architraves seems like a bit of bodge job.
Anyone deal with anything like this or have thoughts on how to approach the fix properly?
Thanks in advance.
Thanks in advance.
